coud be the float in the oil tank is sticking
can test it with an ohm meter
do you have the factory service manual
Would that be the 2" sqaure box or is it in oil tank.thanks for all your help!
Replaced module and still have alarm,I found badly croaded connecter under side rail,thought that was it hard wire and still alarm,same thing unsrew tan wires from block alarm stops touch them together alarm sounds tan wire comes from module then to block then to small red alarm under side rail then changes to purple wire to key switch.Could it be bad alarm or ground?
Your say when its grounded alarm sounds,should it not be grounded or better ground?I can't wait to figure out this one.
