Evinrude Dying at WOT
mlschmitz
I am sending this for a friend so I dont have a lot of specs on his motor.
He has a 90 hp Evinrude. It starts and idles fine. It runs great at low to medium rpms under load. When he punches it,:confused: it will rev up normally and then die (shut down) after a few seconds. After that it starts up again and runs fine.
Any ideas out there??
Thanks
kenmyfam
Re: Evinrude Dying at WOT
Well I hate to say it but a basic health check would be a telling factor.
Compression
Spark
Fuel delivery
Spark plug condition
Go from there.
Sounds though more likely it is fuel related. Pump on it's way out or carb's need a thorough service. That is just purely a guess at this point though.
More details on the motor would help. Year, model etc.
tootallofwa
Make sure the fuel tank vent is open. Maybe a problem with fuel pump.
glassmaster68
something as simple as the bulb[pump up] hose from tank to engine having slight leaks also will give the same effect,if thats what you use,,,,,so you[or your friend] have quite a few things to look over,there is a number of things that would cause your described symptoms,good luck,let us know what you come up with
