Hi I picked this motor up last year I saw it run and saw trim work up and down, I was keeping it as a spare but it seems I am going to need it as my motor lost two cyl.. anyway took off my engine and installed the 115 evinrude I think it is early 80`s motor no tag or i.d marks that I know of .. I hooked everything up started it up runs pretty good but can`t get the trim going.. I am pretty sure I have it hooked up correctly I just put the blue wire from the trim to the blue wire on my boat and same thing with the green just really matched up the colors when i hit the button I can hear the relay clicking but nothing happens trim motor appears to be full and I was able to raise it manuelly but it was rough , the only way I could lower it was useing the release bolt on the side of the transom mounting bracket.. It was wired the same way with the previous motor and worked well never had a problem I checked and rechecked my connections any ideas or suggestions would be appreciated Thanks Bill
