Fly wheel compatibility help?
Rubixone
I found a fly wheel in good condition on ebay its a 1963 evinrude 40hp and I have a 1961 johnson 40hp these wheels look identical can any one verify that it is compatible?
F_R
Re: Fly wheel compatibility help?
NO! The 1961 has the small crankshaft.
Rubixone
so will the fly wheel from 35 hp from the same year 1961 fit it?
Rubixone
so willy is china wrong then whos right?
F_R
There was no 35hp in 1961. The last 35hp was 1958. But it did have the small crankshaft, so maybe-possibly. I would have to do some research to be 100% sure in this case.
BTW, Chinewalker is a good and knowledgeable man. He just made a mistake. Actually, the reason the crankshaft size was changed was because they were breaking. Therefor, it is possible that the 1961 COULD have a large crankshaft, if it had broken and if the powerhead has been replaced. That would make Chinewalker the winner in the debate.
You can tell which shaft you have by the flywheel nut size. The small crank has a 7/8" nut (wrench size), and the large crank has a 1-1/16" nut.
Chinewalker
Frank - I was under the impression that 1961 was the changeover year due to the cranks breaking in 1960 model year. Was it all '61s, half, or none that got the small crank??
F_R
Good question. All I have is the quick reference book that says:
580334 fits 1960-61 (w/o ring gear)
580335 fits 1960-61 (w/ ring gear)
580410 fits 1962-up (w/o ring gear)
Did some 1961's get the new crank?? I dont know. Possibly. I do know that some powerheads got warrantied.
R.Johnson
The 1963 crank was larger ar the flywheel hub , so the fyywheel of a 63 will not fit a 61 hub. I don't really remember whe this change took place. seem 's it was mid-year, but not sure.
Rubixone
so if i got this right then it means that there was no 35hp in 61 so I must be wrong about the year.and that the 1963 40hp has a larger crank shaft (so that fly wheel wont work) than the 61. i can also verify that two numbers that 580334 and 335 are in the part catalog as the compable fly wheels.:confused: right?
F_R
Right. The only unanswered question is whether or not you might have a '61 with a big crank. Measure the nut and you will know.
Rubixone
the nut on top was like a 1 in socket to remove i think i will double check. pretty sure though cause i had a standard one inch ajustable rench on it at first. but i will go check in just a little bit.
Rubixone
ok so with a tape measure i measured the top nut from outer edge of nut to the other outer edge the nut is 7/8 of an inch. so from one side to opposing side, exactly 7/8in.
Rubixone
does that mean I have the smaller crank shaft then? I am pulling the wheel to day and I'll upload images with measurments if tHAT will help.
Rubixone
I need to know what to torque this nut down to in lb for this fly wheel. Please help
Rubixone
is it 60-65 this pdf says some thing like that but I wan to be sure.
