Engine is 1995 Mercruiser 3.0LX - 0F365904
Drive is Alpha 1 2nd Gen - 0F384359
Recently I had a problem with my engine overheating. I found a hose in the back of engine block loose and re-clamped it, which solved that. I replaced the thermostat as well. The engine will run cool up to about 3000 rpm at which point it overheats.
After inspecting the outdrive in the full up position, I noticed that a large accordian-style hose has most likely burned off during overheat or is possibly rotten (i'm guessing burned). It is a large hose that goes straight into a large hole on the gimble housing.
Does anyone have a part number for this hose and know what it is called?
Does the entire outdrive have to be removed to replace it?
Thanks!
Thanks!
