floatingwoody2006
- Feb 2, 2006
- 500
Neighbor just got a 14' grumman with this old girl, and it looks like it's worth saving. Having spark issues though. Wires and boots were corroded. so far i have done the following. Compression is at 96 psi per cyl. Took the flywheel off, and inspected. one coil was cracked, so that was replaced. Other coil looks new no cracks or damage whatsoever. Replaced both coil wires with 7mm metal core plug wire. lightly Sanded points. put back together and saw spark on one of the 2 leads once. Otherwise, i am not seeing any. condensors and points appear to be in good shape and not burnt, and generally they don't fail correct? Im thinking it could somehow be out of time maybe?
