billysboat
- Apr 24, 2010
- 50
Just being new to this forum and after receiving a warm welcome, I thought I'd share some of my experience as a professional painting contractor. After reading the post about using vasoline to restore a shine on fiberglass, I will just add my two cents. I've dealt with oxidation for years, mainly on oil based paint and anodized aluminum.
Product knowledge is the key to my success and now I will share some of it with you. Please use care when using the products I am recommending, read the labels and follow all of the safety precautions when using them.
If you have heavy oxidation (chalk appears on your hand after touching it) you should use a product containing oxalic acid. Scary as it may sound, oxalic acid is also known to be used as wood brightener or wood bleach. (It is not the kind of bleach you use in the laundry) It is used on exterior wood decks mainly to restore woods natural color before restaining. Many paint stores will carry oxalic acid in some of their exterior cleaning products. A good scrubbing while using product will help remove any loose chalk that is on the surface.
After the cleaning is complete, try using a product called Penetrol. It's main purpose is to thin oil based paints for spraying and increases leveling properties. If you read the label on the can like I have, it mentions how it restores dull, faded fiberglass. It comes in a regular and a marine version. I have no idea of the difference in these two products but as we all know marine = $. I told a friend about it and he used it. He liked the way it worked, didn't take long to apply, but only lasted about one season.
The point of me telling this is, is in contrary opinion of using vasoline. You can't paint over vasoline, and extensive prep would be needed if you ever do. Penetrol dries and once it is dry, a hard finish is created. Use sparingly though as the label stares. Although I have never tried it may take a wax to make a more beautiful shine.
Tell me your results and opinions on this topic. And again, Thanks for the warm welcome.
