I have a problem with the recoil starter on my Seahorse. I took the recoil assembly off to clean and lubricate it to begin using the motor again. Somehow, now that it is cleaned and lubricated the arms that are supposed to pivot inwards to grab the flywheel are not pivoting as they should.
There is a brass colored ring in the assembly that is held in place on the recoil wheel by a type of collar and this ring has 3 small springs that attach to each of the pivots. This brass ring also has a spring on the bottom that I believe is the problem. I can't determine if the spring on the inside of the brass ring is supposed to lift the ring to cause enough friction on the collar to make the ring rotate and pull the pivots out to engage the flywheel or if the spring in question is supposed to be stopped by a tab on the recoil wheel and somehow rotate the ring and pull the pivots.
To sum up the problem: after lubricating and reassembling the recoil assembly, the pivots don't pivot.
Any help would be appreciated. I'm trying to take my brother from out of town fishing in two days and won't be able to if I can't get the motor started.
Thanks in advance.
Thanks in advance.
