bramiller310
- Mar 31, 2010
- 10
I had to pull the carbs off and take one of them apart cause the float was stuck and it was leaking fuel. So I got this done put everything back together and the fuel has stopped but not the motor will not stay running. When I crank it it will start and idle up real high and then slowly come down and hold at normal idle rpms. When it idles at normal rpms it is running rough and then it will die out. Could I have did something that I am not aware of when I pulled the carbs apart that is making it do this? Any and all help is greatly appreciated. I am trying to fix it and sell the whole rig. I am hoping to do this pretty quick. Thanks in advance for the help!
Brandon
Brandon
