acollins74
- Apr 25, 2010
- 18
1994 Mercury 75 HP.
Coming home this afternoon, i noticed my motor was sluggish as if I were driving a Stick Shift with a bad clutch. The motor seemed to be running fine but I couldn't hit top speeds and noticed the hot buzzer went of when I tried to WOT. Plenty of water coming out of pee hole as expected.
When I got home, i pulled the cap when i flushed the motor to check things out. Well in the rear of the motor water was squirting out of the side (head gasket?) as well as water was still coming out of the pee hole as expected.
I am thinking i blew the head gasket but I can't find anyone else that had a blown head gasket and also had plenty of water shooting out of the pee spout also.
Does this sound like my head gasket is blown/broken?
It seems fairly straight forward to pull that part of the motor but do not know the torque nor the order.
Also, I'm a little nervous of what caused the issue in the first place. I'm a noob to mechanics really but don't want to bring the boat in because I do not know which shop to take it over. Mostly marinas where I live and I don't have alot of cash. Thoughts?
