fuel pump 5.5 evinrude fisherman 1962
oldjonboat
Hello,
I have a 5.5hp evinrude fisherman 1962 model # 5524R. I am in need of a new fuel pump. The part # on the pump is 304089. I am under the impression that that specific pump is no longer available and I need to get a newer style pump sierra part # 18-7350. Can anyone verify this! I just want to make sure before I buy it.
Also a side note dose anyone know what happen to www.vintageoutboards.com
Thanks
oldjonboat
ezeke
Re: fuel pump 5.5 evinrude fisherman 1962
OEM 0304089 is superseded by 0388685.
F_R
Hello,
Thanks
oldjonboat
18-7350 is available right here at iboats. It will work if it will fit in the space available and the hoses will go on without some obstruction being in the way. You may have to re-route the hoses.
oldjonboat
Cool, I was thinking I was right just wanted to double check. As long as it bolts up I think it will fit fine and hoses are no problem. I order 90% of my part form Iboats.com. Including this fuel pump. However, I did like the impeller kits vintageoutboards.com sold.
