Re: choke question 120hp '91 Force
If the motor is a 1991D model, or newer, it will not have a choke solenoid.
Instead, it will have a fuel enrichment valve, or primer.
This valve dumps fuel directly into the intake, behind the carb.
So instead of having a solenoid that actuates the carb buttterflies, there is a valve with a fuel line running into it, then a fuel line that runs up into the manifold.
Operation is the same.
Push in on the key and hold it in, while turning the key.
Fuel will be dumped into the manifold.
