opalized
- Apr 17, 2010
- 31
well, each day that passes, shines a new light on the whole in my wallet.
I awoke to a sunshine day and a intact transom, i will fall asleep inchy, with no transom plywood.
First question
the brass insert, the drain hole for the bilges, what do i use to replace this because its gone now? (preferably one that doesnt leak between the outlet hole and the hull around it).
Question two, PL i hear reference to this product some kind of laminating glue?? Where do i find it what do i look for. This will be in regard to q 3
Question 3
plywood for the transom, do i use one piece 1" 3/8 thick or 3 pieces laminated together, what i remove seemed to be 3 pieces seamed together the grain goeing side to side then up and down and then side to side again, sound right?
Can i get away with regular plywood, or must it be marine grade?? the inside will be coated in fiberglass i would assume, and the boat side laminated or glued to the fiberglass that remains of my transom...
The original culpret of the water entering the transom to rot it appears to be one them add on ski tow bars, (not factory) the bottom wholes where hogged out bad. So now
How do i fix it so it wont do that again to my brand new transom, steel stock inside the fiberglass with steel insert through the plywood so id it does leak it leaks inside the boat instead of inside the plywood to slowly rot it out again.
Any ideas on this matter Greatly appreciated
Sincerely
Dave of the disappearing Boat
Picture included in the pic, you can see the tow bar bolts the right side plywood has been removed on transom left side is still there and you can see the rot coming from the bottom bolt was the same on both side clearly these bolts spend most there time under water while the boat is in the lake, i have to find a solution or i cant reinstall this ski tow bar
First question
Question 3
Sincerely
