Re: Hi Idle screw
Sweeper Force,
I had to figure this one out too. From your phto, if you follow that rod down to where it has a smaller rod attached to the carb cam, there is an adjustment screw with a locking nut to the left of it back against the block. I don't have my manual out or I'd give you the correct name.
