Re: Weak or no spark
check all grounds at the powerpack and coils,be sure all connections are good,that means that all pins are not getting pushed out back of the connectors,spark plug wires are clean and rust free in the boots,you might then check spark after disconnecting the red harness plug and supplying positive directly to the starter,if you crank it with plugs in and connected,it may start,and you cant stop it ,and if no water is connected ,you will burn the impeller,so I suggest you do a spark test,if you then get spark,check all harness connections,you can then disconnect the small black/white wire at the powerpack,this is the kill circut,it puts neg.to the pack when key is in off position,if you get good spark,your keyswitch is the likely culprit,or a safty lanyard switch or any kill button,they may be passing neg.when not supposed to
