I have a 94 Johnson 48SP that wouldn't idle longer than 5 secs or so last year without me having to pull the lever up to keep the engine revved. On several occasions, it also wouldn't shut off by turning the key or pulling the safety cord. I'd often have to toss the throttle back and forth to get the idle to come back down and then let it stall out (slammed into a dock 1st time this happened). Also, for no reason, the tilt/trim would just start working outta the blue, even when sitting in the driveway, but i'd have to play around with the switch on the throttle and motor sometimes to get it to work before launching (IF it'd even work then).
So this year, i took it to the shop specifically asking for the carbs to be rebuilt. Instead, they said I had a bad power pack and one of the cylinders wasn't firing, stating this was the cause for the bad idle, tilt/trim issues, and not shutting off. Would a bad power pack really cause all these symptoms? I had a friend adjust the carbs for me last year and said he was unable to get it to idle at all using the low jets.
