Bin Ladder
Bin Ladder
Imports are a real headache & time consuming and being a practical boater decided to make my own, after testing several methods, found all to be non water convincing or bulky. This Bin Ladder is very practical, fits in a small pouch and costs peanuts to make; any related name, is pure coincidence
1-Iy you happen to have a seat you don't use at all, remove hook, or can get a spare plastic seat hook, make a middle cut and pass a 2.80 Mt 25 mm belt, sew loop, pass other side through a water tube about 25 cm width and 23 mm in diameter, make a triangle tigh knot. If you want it to be a height adjusted ladder can place a stainles steel buckle where triangular portion is formed to vary heigh accordingly for child/adult use. (Pic-1)
2-Place seat hook on left tube seat handle patch, extend to right patch and form a loop so to distribute person's weight and pull evenly on both patches, pass it through middle right tube handle untill sinks. (Pic-2)
3-Adjust triangle height so to have at least a 100? angle with knee, place right foot on traingle, while standing on tube pull yourself up while grabbing with other hand inside belt portion (before loop) an easy stand & pull step combination even for ladies. (Pic 3-4)
This application is only for fronbt/rear empty seat patches, if no patches are available inside sib can place and secure seat hook on life lines.
Happy Boating
