Picture need for 125 volvo water pump
-JR-
Trying to find a picture and part number for a 1984 volvo aq125a waterpump
What I need is the shaft.....Can anyone direct me a picture as my S.N not working on that other parts site.
Anyone no the coast of one.
Thanks
JR
tbear1964
Re: Picture need for 125 volvo water pump
impeller shaft or circulation pump?
-JR-
impeller shaft ,found a picture from a parts site but no part number or price.
tbear1964
I'll start Googling too. LOL
-JR-
Having that picture you might also have some advice like ...
What do you set your timing at ,as mine is alittle hard starting after running her for awhile when set at 10 degree.
When set lower she likes to desiel on,when I turn the key off.
I also have a solex carb ,there is a upper air screw what is it set at on yours ..about 2 turns out. lower one set at 1 1/2
tbear1964
http://www.dougrussell.com/partscat...,1880,1881,1882,1866,1887,1870,1886,1875,1877
I found a repair kit. #875698-3
$75.00 and out of stock.
Ebay for $90 or best offer, but shaft looks different....notched at both ends
http://cgi.ebay.com/ebaymotors/Volv...at_Parts_Accessories_Gear?hash=item51805a625c
this one looks better--$75 and the shaft looks correct.
http://cgi.ebay.com/ebaymotors/SIER...at_Parts_Accessories_Gear?hash=item35a5632135
dougrussell shows the part (9), but not the number (apparently not sold individually)
That's all I got for now, sorry. Looks like the Sea Water Pump is the same on many of the OHC Volvos....FYI
tbear1964
I had a mechanic do a full tuneup 3 years ago after I bought it, and I've never touched the carb (except replace the banjo fitting) or played with the timing. Can't help you there. Runs great, whatever he did. LOL
I can check some of the things next week. Boat comes home from storage Friday....
-JR-
the second one looks corect ...thanks
tbear1964
Boat is home, but we're due for some Biblical rain tonite/tomorrow. After the weekend (unless we get a break) , I can check the carb settings.....I'll check the timing when I can pry it away from my neighbor.....
