I am doing boat wiring for the first time so bear with me.
This is a new pump, automatic type. Old pump was standard turn on/off pump wired to the switch on/off at the helm. The boat does have a fuse panel under the steering console with open spots.
I want to wire this new pump so that I have an on-off-on switch at the console. It will be moored at the dock so I will want it switched auto-on with a capability for manual overide- a momentary on situation.
I have a 5amp inline fuse like the directions call for that I could install directly to the battery. But do I even need to do that if I can run the ON side of the switch to the fuse panel at the console?The schematic shows the inline fuse between the battery and the PWR pole of the switch, in this case the middle pole. Can't I run a wire from that pole to the fuse panel with a 5 amp fuse at that point?
If I need to run it directly to the battery what kind of battery connection do you suggest?
Thanks,
Joe
Thanks,
Joe
