Dan F.
- Feb 10, 2010
- 13
Current test prop is a Solas alum.15 1/4x15p. Want to install a stainless but it appears no one makes the same prop in stainless. Turning 4900rpm @WOT on a 2000 model Mercruiser 4.3l efi which is 100 rpm too much. Figured the stainless would knock that 100 off since there is less flex and gain a couple more mph at the top end. Other important info is boats an '85 Wellcraft V-20(heavy boat) and top speed right now is 48mph. Should I go with another 1/4" of diameter with the same pitch or less diameter with more pitch? Just repowered and am confused as what to do. Thanks for any advice in advance.
