1999 50 hp J'son V RO to std fuel pump
joleejones
Am changing to a std pump, 2 carbs, will 1 std fuel pump work? What about the wiring that is connected to the VRO,tan,gray,purple and black.
The fuel manifold assy. has 3 ports upr and lwr go to carbs do you plug the ctr one?
A hose from the old VRO goes to a port under the lwr carb do you plug that one?
The fuel manifold assy will have to be turned upside down to accommodate the fuel line from the std pump does it matter which ports go to the carbs, upr port to upr carb lwr port to lwr carb?
Thanks
