My engine runs great, but at WOT it will slip out of gear into neutral and send the rpm's out of control. If I hold the shift lever down the motor will not slip out. I'm fairly knowledgeable with small 2-stroke outboards, but I cannot get this problem fixed. I took apart the lower unit to inspect the gears, but I cannot figure out how to get the forward gear out of this particular lower unit. Does any one know how to remove the forward gear? Also, does anyone have any suggestions as to what may be causing the problem? Thanks
Ryan
Ryan
