Re: Cheap epoxy or poly resin?
If the rest of the wood has a clear and somewhat thick layer of resin without glass covering it, it will be epoxy. Polyester won't stick to epoxy very well, nor will it hold up without glass, so what you have is most likely epoxy. If its a very thin layer it may be some other type of coating.
