toock the stern drive off and some parts fell out
HT32BSX115
Re: toock the stern drive off and some parts fell out
Howdy,
It's really good if you post your engine and drive serial numbers.....
Those look a lot like the exhaust shutters!
Cheers,
Rick
fuzzybob
Exhaust flappers. They go in the Y tube inside the boat. You can do a search and find a lot of info on them in the forum. It's a common prob.
You can go to the top of the forum, Adults Only sticky and download the OEM manuals for your engine and outdrive and see how to replace them. Good luck
HT32BSX115
If you have a V-8, here's generally where they go.....
#7 below... it's a picture from Doug Russell parts, but you can probably get them right here on iBoats!!
billywhizz
Done the same thing last week, I think you will find they are the remains of your flapper/water shutter, that lives in the exhaust pipe ,you need to replace to keep your engine safe from sea water,
