98 MerCruiser v-6 carb. alpha drive. riser on one side of engine gets hot to the touch and the other cool. I'm running it out of the water and can see the cool side of the engine has much better water flow out. Moved the trailer and the situation has reversed. Circulation pump is not leaking ( so it's good? ) Thinking my water P/U impeller isn't moving as much water as it should. Thanks for your help.
Hugh
Hugh
