Re: 1973 55 HP Chrysler outboard, Points, Condenser And Timing.
1. Do you have a good understanding on positioning the cam to set the duel points and the feeling of the gap? Are the points pitted are just dirty (which could cause the kick-back I feel you mentioned? From my reading vs experience the wrong condenser will cause the points to pit/burn prematurely.
2. My point remains, if you are not sure about how to time the engine and it?s not kicking back or backfiring, lack of burst or power and Etc. You might be better off to leave it to the local O/B mechanic. I at least like to read the process and understand it. Then, I want an experienced mechanic that knows the process watch me and verify that I?m doing the process correct ?start to finish?.
3. The timing is 32 Degrees BTDC but I have read 28-32 could perform better. This goes back to my position on setting the timing if you understand the procedure and if it is needed.
4. Could one of our Chrysler Pros refer us to video clips link on setting the points and timing? OR! Make condensed clips and tips and send us the link. Even at a price for the clip if they are not on the market. That would almost be as good as an in person demo. Clymer has graphics and directions but I am not getting that human sight of it being done. Most of all I know there will be the difference of opinions in any operation.
I hope I Have Not Stepped Into Something Deep! JOW
