67 evinrude water flow
chuckpeterson
'have a 6 hp that has what I think is slow or minimal water flow. Runs good however worry it might be overheating. What's the standard?
D
DJ
Guest
Re: 67 evinrude water flow
Your first clue of an overheat is holding your fingers on the top cylinder head. If you can count to three without discomfort, you're OK.
Those engines typically run about 140-150 degrees F, or less.
