whats is this pin hole for on the lower unit above the prop? air?? old unburned oil an gas??
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #1 whats is this pin hole for on the lower unit above the prop? air?? old unburned oil an gas??
bktheking Vice Admiral Joined Jul 29, 2008 Messages 5,057 Apr 14, 2010 #2 Re: pin hole 62 5.5 fisherman Thinking it's drain hole.
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #3 Re: pin hole 62 5.5 fisherman any clue as to what kind of drain hole.. thanks Josh
bktheking Vice Admiral Joined Jul 29, 2008 Messages 5,057 Apr 14, 2010 #4 Re: pin hole 62 5.5 fisherman Thinking water, but i've seen unburnt oil come out of my motors as well.
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #5 Re: pin hole 62 5.5 fisherman ok so water or unburned oil coming out a lil is really not a problem? my 57 7.5 has the same pin hole. so i kno its supposed to be there.
bktheking Vice Admiral Joined Jul 29, 2008 Messages 5,057 Apr 14, 2010 #6 Re: pin hole 62 5.5 fisherman Nope, all part of the drainage once it comes out of the water.
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #7 Re: pin hole 62 5.5 fisherman great. thanks
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #8 Re: pin hole 62 5.5 fisherman any clue as to what weight gear oil it takes in the lower unit
J jeff_smith_0423 Chief Petty Officer Joined Dec 5, 2007 Messages 492 Apr 14, 2010 #9 Re: pin hole 62 5.5 fisherman I had a '61 and it always did fine on standard 80w-90 marine gear lube.
Y yzsanttrs Cadet Joined Apr 8, 2010 Messages 14 Apr 14, 2010 #10 Re: pin hole 62 5.5 fisherman great thanks all
