Bassam ahmad
- Apr 14, 2010
- 2
Hi,
I jus bought a two stroke Mercury Thunderbolt 500 (50 HP) outboard for my boat. The engine was winterized when I purchased it. After charging the battery, adding fuel mix and lower unit gear oil I started the engine (at home with running water) and everything was fine. I engaged the propeller in both directions and it all functioned well.
The next day I took the boat to the marina and the engine won?t start. After I switch the motor, the starter engage the flywheel and turn it for a short distance and stop (i.e. the starter will not keep running the flywheel) and some times it will not turn at all. I thought maybe the battery was not good so I connected it to my car through jumper cable. Same results.
Do you have any idea what is going on?
Thanks
Thanks
