Converting to 2BBL to 4BBL
dobler5
Hey my first post!
I have a 1991 4.3L GM OMC COBRA with a 2BBL Carb. I just bought a 91 4.3L HO OMC Cobra engine that was cracked during winter storage. I was just going to part out all the parts. I noticed it has a 4BBL Carb. Can I put that on my engine? If so, what all would I have to do? Would it be worth it? Etc. I am a dummy when it comes to engines. Thanks for your help!
Gary H NC
Re: Converting to 2BBL to 4BBL
Welcome to Iboats!
Swap the carb and intake manifold.
Same vintage motor so it should be an easy switch...
duke3478
Swap the heads and cam while you're at it, and then you'll have an HO, too. I think...(?)
CharlieB
Heads and cam are the same, stay with the simple, swap the intake assy.
180shabah
Swap the intake and carb, the heads and cam are the same. You MUST use the HO stickers to make full power:cool:
