Cracked Exaust Bellows A Problem?
350mpi Guy
Merc 350mpi Alpha1
I have thru-hull exhaust and was wondering if the bellows should be replaced? It doesn't appear to be cracked but the boat sat in the water for the last 4.5 years and the bellows looks dry rotted.
NHGuy
Re: Cracked Exaust Bellows A Problem?
Make a decision based on your best estimate. But you have undoubtedly heard the old saw, "an ounce of prevention is worth a pound of cure."
180shabah
Dryrotted = replace
ujoint bellows should be done also.
bruceb58
Honorary Supreme Mariner
If you have thru hull exhaust, you really don't even need the exhaust bellows. So the answer is no.
You should defintely be pulling the drive and replacing your u-joint bellows though. Hope you are able to get the drive off!
