Re: ripped exhaust bellows
It's an Alpha One.
I was wrong, it's not the larger one and from what Don S said thats a good thing. The ujoint bellows and shift cable bellows look to be in good shape. I will keep my eye on them... Do you have to take the outdrive off to replace? looks like you do
You do need to pull the drive to replace that bellows. Pulling the drive is 6 nuts on the drive and then 2 more where the trim cylinders attach at the rear (iirc). Pulling off the drive is not much work.
To replace that bellows, you probably will need the "bellows tool". It will reduce the cursing and time it takes to get the bellow installed.
An Exhaust Tube can probably be installed with the drive still in place. It only hooks up on the transome end. The exhaust tube does not need a special tool. The downside is the exhaust will be louder, although most people say they did not notice a difference in noise when putting a tube in place of the bellows.
Replacing the U-Joint bellows BEFORE it rips saves you a lot of $$. More than likely, it will tear, you won't notice it, or you are already in the water when it does happen, then you get water in the bellows which will ruin your gimbal bearing ($60), your u-joints (~ $30 each) and possibly will get water into your drive (depends how much, how long there). The u-joint bellows is also a path for water to go straight into the boat via the gimbal bearing.
