fishingcowboy
- Mar 11, 2010
- 23
I'll try and get some pictures up tomorrow, but on my 85 Dynatrak, I have some wood rot in a couple strange places. When I bought the boat, there was a decent crack at the base of the transom, right at the bottom of the boat. Expecting a rotted transom, I drilled some pilot holes, and they all came back dry. I dropped the motor straight up and down and stood on the motor, and no flex was noted and no cracks appeared. I'm going to clean up the cracked portion (once I get the stern off the trailer so I can access the bottom of the crack) and either re-fiberglass or epoxy it, depending on how bad it looks. My real issue is that in the box (sorry, I don't know what it's called...its where the batteries, gas tank, oil tank... are located), there is quite a bit of rot under the battery on the starboard side. What are the chances this is simply floor rot, and the rot doesn't extend into the stringers. The floor under the battery covers on the port side looks fine. I've drilled multiple holes in the deck throughout the boat to double check the solidity of the wood and this one place is the only place I've found rot.
What should my next steps be (other than getting pictures posted)? Should I cut out the floor under the starboard battery and replace it? I've seen epoxy that is advertised as a solution to rotted wood. Would this work? I don't want the rot to spread, but also don't want to tear up my entire deck and transom if a simple fix is all that's needed.
