Picked up a boat in Jan. took a chance that it ran, and "the guy said it did"....
135 evinrude power trim! Can't seem to get it fired up, put new plugs in checked spark by grounding plug and cranking. Got spark on all 4 cyl. Noticed that the heads are marked in ink 135 & 140 140 & 135, my guess was someone recently did a comp check.
I checked them cold and all are at/around 120. My tester may have a small leak @ head fitting but 120 still seems ok....ish.
Once I figured out that the elec. choke was push key in, thought I had it aced...
NOPE... I did notice that when I choked it & cranked for a bit fuel seeped out the front of carbs.
Even went as far as quick start, (I try not to use on "pre mixed" 2 strokes but desprite times)
Not even a fart/cough. Makes me think stuck needle/floats,??
Should I order carb kits?
For the record, Model # is 135383m Serial # is C 94125
If anyone can identify year of this beast I would love to know
