Re: alcohol stove????!!!!!
The thing with alcohol stoves is you have to pre heat the burner, pump it up, release a small amount of the alcohol, turn off, carefully light (have the fire extinguisher close), it should burn for not more than 30-45 seconds, open up the valve slowly, and you should have a flaming burner (it has to be really hot when you preheat it).
NOTE!!!- if the rubber seals have deteriated it will start to flash on you (spitting out lots of raw alcohol), turn it off.
At this time I am trying to replace ours with a small two burner propane style like in a camper, but I really prefer to cook outside of the cabin.
