Re: help!did i get ripped off?
sorry i didnt clarify.
i did run it a good couple minutes.it seemed really hot.3 count would burn.
i had the water up to the fin above the water inlet.
the guy said the water pump was just replaced.
the motor was painted really recently.and i could see gasket maker behind the carb.
the guy was selling two motors at the same time.he said that another guy came and got the other motor and offered him 600 for both.but he told him no because i called first.he said that guy did a compression test on both motors.
this is the same motor as mine.
http://www.youtube.com/watch?v=boz65jDewR4
Based on what you have described, it sounds like something was mucked up during the water pump install... as mentioned, you should see "something" coming out of the holes ( mist, water, etc,) after 30 secs or so, if you cant touch the head, then its definitely not cooling properly...
I would talk to the person who sold it to you, and test run it in a tank together, and if it doesnt work, see if he will either get it fixed, or at least buy you a new kit to install... (if he is absolutely sure its brand new, then I would check to see if it wasnt installed backwards... they will pump that way, but not very well at all).
Its also possible it was installed and run "dry" initially (installed without a lube and ran without water) which stripped the splines off the impeller... you need to start there.
If its installed correctly, then you need to check for blockage in the tube running up into the bottom of the motor.
Not sure what else to tell you, they are pretty simple systems.
