Re: liberator 211 restore, need help bad
Hi Stefan!
I don't hang out in this section much so I didn't see your original post last year....
I hope you're still working on your Lib..... It appears that FW didn't do a very good job on the Libs (or any other ones) Doesn't say much for FW quality does it??
When I did my re-power, I noticed that the transom doesn't fit all that well. They left a gap below the transom-wood that could fill with water. (and mine did) When I drilled below it a fair amount of water ran out.
I was VERY lucky. I had no rot at all. It did take a few months to completely dry it out though.
After I dried it out, I pressure-filled the void below the transom with MAS epoxy mixed with milled fiberglass.
My stringers were fine but I noticed that FW didn't seal the drain hole at all at the bottom of the transom (the source of my water intrusion in the transom)
Before:
After: You can see here that I hadn't yet drilled the drain hole.
I also moved the bulkhead in front of the engine forward a couple of inches to allow for a little more room in front of the engine. The fuel tank fits pretty tight now though.
I re-glassed the entire engine compartment using MAS epoxy resin and painted it all with BilgeKote
I hope you're coming along well. (or done!)
Sorry no one replied to your post!
Regards,
Rick
