I found a small, green-tinted oil stain (no pool) on the concrete under the skeg on GENII drive, OF461347, and traced it back to the small "weep holes" just above the AVP on each side of the housing. The drive is installed on a 1995 Ebbtide 192SE with only 88 hours on the Merc 4.3LX and has not been run since being winterized in OCT2008. It has been stored in a garage with the drive down. Part of the winterization was to run the engine on a remote tank using outboard 100:1 premix and then fogged the cylinders with aerosol spray (forget the brand). Do I have a gear lube leak and, if so, where do I start looking? Thanks
