87 model Force 125, tach is off (I estimate by at least 1000 rpm (it shows to idle at 2500 rpm!). Full throttle shows at 7000 rpm, thought it was just a matter of change setting on tach , it is set at 6 "pul/rev" whatever that means but that doesnt seem to corresponding with the no of cyl (4cyl), I cant find anything in the manual about tachs so I will move it to 4 and see if that helps.
Taking the family out today and will see how that works, if anybody can clue me in I would appreciate it , will check back later. Thank you in advance.
