Re: 6 hp shifting problem
The positive click stops for the shifting lever is by a Ell shaped bent spring that snaps into notches on the shifting rod inside the lower unit. This spring & a helper spring are screwed into the lower unit above the prop shaft & mate into notches in the shifting rod. If your motor's stops are non-functioning, the spring & helper cvan be there & OK, just that they had gotten slid forward enough to not engage into the rod's notches. So it is just a simple matter dropping the bottom 1/2 of the gearcase & of realigning them & retightening the screw. Then reassemble the gearcase.
