The rear of the engine is sitting about 1/8" to 1/4" too low...the bar will not even go into the splines and I can see it hitting the top of the splines.
At first I thought the rear engine mounts were bad. They looked very good when I inspected them and I lifted the rear of the engine up with a jack and then compressed it and saw no sinking of the rear mounts.
I have the spacers and fiber washer installed exactly as they came out and to the Merc. Manual specs.
When I jack the rear of the engine up I can get the alignment bar to go in 2"s and figure the rest if front adjustment.
I actually went so far as to stack some washers under the stock spacer and this also worked, but seems like a rig...
One thing that really bothers me, when I had the transom assembly ready to put back on there are oval holes on the inside engine part of the transom assembly. I tried to center it as much as possible, but because of these oval holes you could have the rear of the engine off up to 1/4" and the Merc manual says NOTHING about these!
HELP!
HELP!
