Re: Merc 115 Ignition Problem
Thanks and I will get the adaptor. I appreciate it.
You need a DVA to diagnose performance problems. You don't need one to diagnose spark issues. A simple multi-meter is all you need at this point and you don't really even need that.
It's not the trigger, the trigger has three coils and the trigger magnet is north south on top and south north on the bottom. Picture it like this..
1 2 3 = trigger coils
1 2 3 = spark plugs
4 5 6 = spark plugs
1 and 4, 2 and 5, 3 and 6 share a coil. Now you know why it isn't a trigger problem.
It could be the stator so swap the red and blue wires with the red/white and blue/white wires at the the switch boxes and if you now have fire on 1, 3 and 5 then the problem is the stator.
