Re: my 1971 evinrude 9.5 sportwin cuts out at high speed
She purrs like a kitten now. Thanks. I recleaned the carb but this time I ground down a screwdriver so I could pull the high speed jet. she runs great now. Thanks again.
i have a question.i used to have this same motor and loved it.
but it started popping out of gear,yet the gear shifter was still in drive.what was going on?
what size screw driver did you use i am having the same problem, the only thing i haven't done is been able to remove the high speed needle to check it and see.
