hollobaugha
- Apr 8, 2010
- 2
I have a 1985 60 hp Mercury and I recently replaced the impeller. I was look at a diagram of the drive shaft and it shows a pre-load compression spring at the top of the drive shaft where it goes into the power head. The pin is on my drive shaft but I did not see a spring when I took it apart. I looked in the housing and did not see a spring in there as well. I have tried to get one several places but the part (20254) is NLA. Could the spring still be in the head? If it is not is it really needed because I am guessing it has been running without one for 100+ hrs since the last impeller I put in it. Any Idea on where to get one or a resonable replacement?
