TRONMAN2000
- May 8, 2009
- 41
I got on the water for the first time this year. It was 83 deg Saturday! The boat ran great, so I guess it survived another rough winter here in Virginia. After I pulled the boat out of the water and began to strap her down, I noticed my gimble bearing grease tube was not where it was supposed to be!! S*@T It was no longer pressed into the gimble housng. I pressed the tube back in place. Obviously, I must have pulled it loose when I removed the grease gun from the zerk durng winterization. So, I guess my first outing this year was with water in my drive bellow. My question is, would you pull the dive and bellows after one outing with the grease tube out of it's place? Or, do you think it will be ok until the end of the season when I pull the drive anyway?
Thanks
Thanks
