I have a Johnson 112 that is putting out up to 16 volts at WOT and about 13v at idle. From what I have read, this is normal and by design. It is unregulated from the factory. It only has a rectifier, not a regulator. Is that right?
My concern is overcharging the batteries and (more importantly) frying my electronics. My depth finder manual says operating voltage from 10-15v. I am considering using a 12v zener diode in parallel at my electronics to protect them. Is this a common fix? How about overcharging the batteries and getting fumes in my bilge. Should I be concerned about that?
thanks
Greg
thanks
Greg
