2001 Yamaha F100- Timing is Everything
hribarj
Stupid question!!! Can you set the timing on a 2001 Yamaha F100 4-stroke?
Are there any timing belt adjustments to be aware of?
Thanks
robert graham
Re: 2001 Yamaha F100- Timing is Everything
If your timing hasn't been changed or adjusted then probably best not to screw with it at all. Good Luck!
rodbolt
ign timing is NOT adjustable on that engine. camshaft belt tension can be checked and adjusted periodically just like the maint schedule says.
hribarj
Thanks Rodbolt. I was hoping that would be the answer.
connemaraisland
Timing is not adjustable, idle is, the timing belt adjustment is by removing the plastic cover, loosening the belt idler pully letting the spring set the correct tension and then retighening the bolt to secure it - Note check waterpump impeller and grease driveshaft at the mid-section bearing. Timing belt replacement every 100 hours ($65.00)
Bob
