62cruiserinc
- Oct 30, 2009
- 287
I have removed everything that would unscrew from my 62 Cruiser Inc. The bilge area needs cleaning and refinish/repair. A previous posting by me resulted in suggestions to scrub the bilge thoroughly with a scrub brush and cleaner.
The problem I am having is with the design of the joint at the keel. The ribs that run down the sides end at the keel, but there is piece screwed onto either side of the keel that the ribs are screwed into from below. I can unscrew the side pieces that run along the keel, but it only lifts up fractions of an inch due to the ribs holding them down. As seen in the pictures below, there is a cavity formed by the space between the ribs and lengthwise pieces screwed to the keel. There is no way to clean out these 5/8" high cavities thoroughly. Maybe a toothbrush would get much of it, but there would still be dirt inside the corners.
Any suggestions on what to do?
The ribs are in pretty good shape so I don't want to rip the whole boat apart.
Most of the "gray" color in the bilge is just dirt, so I should probably first wash and scrub it to see the actual condition first.
Thanks
Steve
Thanks
Steve
