I have a 1994 Force 120 that I need some help with. At idle the motor pumps water out of the two water holes on the rear cowling. When I put the boat in gear and start to increase the throttle, the water stops pumping out the holes. In fact, when I have it at ? to full throttle, I can place my hand over the two holes and feel suction. I placed the motor in a run tank without the prop to see if I could figure out what is happening. Without the prop, the water will pump out of the holes at any speed, but when I install the prop and give it some RPM, it quits pumping. Can someone help me with this dilemma?
