I have a 1997 90hp Johnson TSLEAU. last time out battery went dead out on the water. i've had some concerns on wether or not my battery was charging from the sator because the volt meter never reads above 11 volts
this saw also comfirmed by the volt meter on my fishing graph. I have a 6amp unregulated charging system on my motor. Also the other thing I noticed was my tach would drop to 0 rpms and than back to normal rpms. This is a new tach alos the old tach did the same thing. I've did ohm test on the staor and it doesn;t check according to the service manuals I have. Any thoughts would be appreciated.
THANK, kEVIN
THANK, kEVIN
